EPSON GS6000 ERROR CODES
Maintenance Request Errors
MAINTENANCE REQUEST - 0001 - The CR scan pass counter has reached the specified value. MAINTENANCE REQUEST - 0011 - The RTC backup battery becomes exhausted.
MAINTENANCE REQUEST - 0111 - The date has not been set.
MAINTENANCE REQUEST - 0100 - The following two errors are occurring simultaneously, 0001 & 0011
MAINTENANCE REQUEST - 1000 - The following two errors are occurring simultaneously, 0001 & 0011
MAINTENANCE REQUEST - 1010 - The following two errors are occurring simultaneously, 0011 & 0111
Service Call Errors
SERVICE CALL ERROR - 1101 - Life end of the CR MOTOR
SERVICE CALL ERROR - 1125 - Carriage home position detection
SERVICE CALL ERROR - 1133 - CR MOTOR in position time-out error
SERVICE CALL ERROR - 1135 - CR ENC ASSY check error
SERVICE CALL ERROR - 1136 - CR MOTOR step-out error
SERVICE CALL ERROR - 1137 - CR servo parameter error
SERVICE CALL ERROR - 1223 - PF ENCODER ASSY check error
SERVICE CALL ERROR - 1225 - PF MOTOR in position time-out error
SERVICE CALL ERROR - 1227 - PF MOTOR step-out error
SERVICE CALL ERROR - 1228 - PF servo parameter error
SERVICE CALL ERROR - 131B - Head driver (transmission gate) overheat error
SERVICE CALL ERROR - 1700 - Print position error
SERVICE CALL ERROR - 1900 - HEATER CONT BOARD ASSY serial connection failure
SERVICE CALL ERROR - 1902 - Over Temp PRE HEATERS(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1903 - Over Temp PLATEN HEATER(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1904 - Over Temp AFTER HEATER(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1905 - Over Temp PRE HEATERS(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1906 - Over Temp PLATEN HEATER(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1907 - Over Temp AFTER HEATER(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1908 - An abnormal voltage of the heater on the HEATER CONT BOARD ASSY
SERVICE CALL ERROR - 1909 - Comms Failure HEATER CONT BOARD ASSY and SUB-B/C BOARD
SERVICE CALL ERROR - 1910 - Under Temp PRE HEATERS(64) on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1911 - Under Temp PLATEN HEATER on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1912 - Under Temp AFTER HEATER on the HEATER RELAY BOARD ASSY
SERVICE CALL ERROR - 1920 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 1 failure
SERVICE CALL ERROR - 1921 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 2 failure
SERVICE CALL ERROR - 1922 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 3 failure
SERVICE CALL ERROR - 1923 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 4 failure
SERVICE CALL ERROR - 1924 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 5 failure
SERVICE CALL ERROR - 1925 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 6 failure
SERVICE CALL ERROR - 1926 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 7 failure
SERVICE CALL ERROR - 1927 - HEATER CONT BOARD ASSY-SUB TANK SENSOR 8 failure
SERVICE CALL ERROR - 1A23 - RTC analysis error
SERVICE CALL ERROR - 1A26 - RTC communication error
SERVICE CALL ERROR - 1A37 - Head thermistor error
SERVICE CALL ERROR - 1A38 - Transistor thermistor error
SERVICE CALL ERROR - 1A39 - Head error
SERVICE CALL ERROR - 1A40 - MAIN BOARD ASSY IC2 error
SERVICE CALL ERROR - 1A41 - Head rank ID input error
SERVICE CALL ERROR - 2000 - NVRAM error
SERVICE CALL ERROR - 2002 - SDRAM error
SERVICE CALL ERROR - 2003 - Boot program sum error
SERVICE CALL ERROR - 200A - Program loading error
SERVICE CALL ERROR - 200B - Internal insufficient memory error
SERVICE CALL ERROR - 200C - Servo interrupt watchdog time-out error
SERVICE CALL ERROR - 200D - System interrupt watchdog timeout error
SERVICE CALL ERROR - 200E - Unknown NMI
SERVICE CALL ERROR - 3000 - AC power shut-off
SERVICE CALL ERROR - FXXX - CPU-related error
EPSON 11880 ERROR CODES
MAINTENANCE REQ - 0001 - The counter of waste ink at borderless printing has reached the specified value.
MAINTENANCE REQ - 0002 - The CR scan pass counter has reached the specified value.
MAINTENANCE REQ - 0008 - The RTC backup battery becomes exhausted.
MAINTENANCE REQ - 0040 - The pump counter has reached the specified value.
MAINTENANCE REQ - 0080 - The date has not been set.
MAINTENANCE REQ - 0100 - The RTC backup battery power has temporarily dropped.
MAINTENANCE REQ - 0088 - The RTC backup battery becomes exhausted and the date has not been set
Service Request Errors
SERVICE REQ - 1101 - Life end of the Ink Tube
SERVICE REQ - 1125 - Carriage home position detection error
SERVICE REQ - 1133 - The CR Motor in position time-out error
SERVICE REQ - 1135 - CR Encoder check error
SERVICE REQ - 1136 - CR Motor Step-out error
SERVICE REQ - 1137 - CR servo parameter error
SERVICE REQ - 1223 - PF Encoder check error
SERVICE REQ - 1225 - The PF Motor in position time-out error
SERVICE REQ - 1227 - PF Motor Step-out error
SERVICE REQ - 1228 - PF servo parameter error
SERVICE REQ - 1400 - Pressure failure error
SERVICE REQ - 1410 - Pump motor drive timeover error
SERVICE REQ - 1430 - Cartridge Holder Maintenance
SERVICE REQ - 1434 - Ink cover unlock error
SERVICE REQ - 1435 - Cap HP detection error
SERVICE REQ - 1436 - Select valve HP detection error
SERVICE REQ - 1437 - Cap motor drive timeover error
SERVICE REQ - 1441 - Pressure motor 1 acceleration error
SERVICE REQ - 1442 - Pressure motor 2 acceleration error
SERVICE REQ - 1443 - Pressure motor 3 acceleration error
SERVICE REQ - 1461 - Pressure motor 1 lock error
SERVICE REQ - 1462 - Pressure motor 2 lock error
SERVICE REQ - 1463 - Pressure motor 3 lock error
SERVICE REQ - 1471 - Pessure motor 1 reverse detection error
SERVICE REQ - 1472 - Pressure motor 2 reverse detection error
SERVICE REQ - 1473 - Pressure motor 3 reverse detection error
SERVICE REQ - 1511 - APG motor drive timeover error
SERVICE REQ - 1536 - Pressurizing reset failure
SERVICE REQ - 1700 - Print position error
SERVICE REQ - 1800 - AID voltage error
SERVICE REQ - 2000 - NVRAM error
SERVICE REQ - 2002 - SDRAM error
SERVICE REQ - 2003 - BOOT program sum error
SERVICE REQ - 3000 - AC power shut-off
SERVICE REQ - 131B - Head driver (transmission gate) overheat error
SERVICE REQ - 150C - PG HP detection error
SERVICE REQ - 16A0 - Cap unit status error 1
SERVICE REQ - 16A1 - Cap unit status error 2
SERVICE REQ - 16B0 - Cap HP detection retry error
SERVICE REQ - 1A23 - RTC analysis error
SERVICE REQ - 1A26 - RTC communication error
SERVICE REQ - 1A37 - Head thermistor error
SERVICE REQ - 1A38 - Transistor thermistor error
SERVICE REQ - 1A39 - Head error
SERVICE REQ - 1A40 - Main board IC2 error
SERVICE REQ - 1A41 - Head rank ID input error
SERVICE REQ - 200A - Program loading error
SERVICE REQ - 200B - Internal insufficient memory error
SERVICE REQ - 200C - Servo interrupt watchdog time-out error
SERVICE REQ - 200D - System interrupt watchdog time-out error
SERVICE REQ - 200E - Unknown NMI
SERVICE REQ - DXXX - Debug error
SERVICE REQ - FXXX - CPU-related error
SERVICE REQ - F000 - CPU-related error
EPSON 7700 9900 ERROR CODES
MAINTENANCE REQ - 0002 - The CR scan pass counter has come near the specified life.
MAINTENANCE REQ - 0010 - Communication with the AID Board is not established.
MAINTENANCE REQ - 0040 - The pump counter has come near the specified life.
MAINTENANCE REQ - 0800 - Cartridge waste ink pad near end of life
MAINTENANCE REQ - 1000 *1 - Ink Selector near end of life
MAINTENANCE REQ - 4000 - It detects twice in a row that all the nozzles are clogging.
MAINTENANCE REQ - 0088 - The RTC backup battery becomes exhausted and the date has not been set.
SERVICE REQ - 1101 - CR life error
SERVICE REQ - 1125 - CR HP detection error
SERVICE REQ - 1138 - Over current error
SERVICE REQ - 113A - Overload error
SERVICE REQ - 113B - Over speed error
SERVICE REQ - 113C - Reversing error
SERVICE REQ - 113D - Driving time-out error
SERVICE REQ - 113E - Velocity deviation error
SERVICE REQ - 113F - Lock error
SERVICE REQ - 122A - Overload error
SERVICE REQ - 122B - Over speed error
SERVICE REQ - 122C - Reversing error
SERVICE REQ - 122D - Driving time-out error
SERVICE REQ - 122E - Velocity deviation error
SERVICE REQ - 122F - Lock error
SERVICE REQ - 13F0 - ICL operation error
SERVICE REQ - 1411 - Select error
SERVICE REQ - 1412 - Pump life error
SERVICE REQ - 1419 - Pump release error
SERVICE REQ - 141A - Overload error
SERVICE REQ - 141B - Over speed error
SERVICE REQ - 141C - Reversing error
SERVICE REQ - 141D - Driving time-out error
SERVICE REQ - 141E - Velocity deviation error
SERVICE REQ - 141F - Lock error
SERVICE REQ - 1427 - CSIC destination setting error
SERVICE REQ - 1428 - Ink holder Board Assy
SERVICE REQ - 1430 - Holder ink pad error
SERVICE REQ - 1431 - Ink selector life error
SERVICE REQ - 1434 - IC cover unlock error
SERVICE REQ - 1438 - Maintenance tank error
SERVICE REQ - 1439 - Cap error
SERVICE REQ - 143A - Overload error
SERVICE REQ - 143B - Over speed error
SERVICE REQ - 143C - Reversing error
SERVICE REQ - 143D - Driving time-out error
SERVICE REQ - 143E - Velocity deviation error
SERVICE REQ - 143F - Lock error
SERVICE REQ - 144A - Overload error
SERVICE REQ - 144B - Over speed error
SERVICE REQ - 144C - Reversing error
SERVICE REQ - 144D - Driving time-out error
SERVICE REQ - 144E - Velocity deviation error
SERVICE REQ - 144F - Lock error
SERVICE REQ - 1489 - Wiper error
SERVICE REQ - 148A - Overload error
SERVICE REQ - 148B - Over speed error
SERVICE REQ - 148C - Reversing error
SERVICE REQ - 148D - Driving time-out error
SERVICE REQ - 148E - Velocity deviation error
SERVICE REQ - 148F - Lock error
SERVICE REQ - 1494 - Ink selector error
SERVICE REQ - 1496 - Ink selector sensor error detection
SERVICE REQ - 1497 - Switching time-out error
SERVICE REQ - 149D - Driving time-out error
SERVICE REQ - 1501 - Release motor phase detection error
SERVICE REQ - 150C - PG phase detection error
SERVICE REQ - 151A - Overload error
SERVICE REQ - 151B - Over speed error
SERVICE REQ - 151C - Reversing error
SERVICE REQ - 151D - Driving time-out error
SERVICE REQ - 151E - Velocity deviation error
SERVICE REQ - 151F - Lock error
SERVICE REQ - 152A - Overload error
SERVICE REQ - 152B - Over speed error
SERVICE REQ - 152C - Reversing error
SERVICE REQ - 152D - Driving time-out error
SERVICE REQ - 152E - Velocity deviation error
SERVICE REQ - 152F - Lock error
SERVICE REQ - 1530 - Driven roller HP detection error
SERVICE REQ - 1536 - Pressurizing reset error
SERVICE REQ - 1537 - Pressurizing error
SERVICE REQ - 153A - Overload error
SERVICE REQ - 153B - Over speed error
SERVICE REQ - 153C - Reversing error
SERVICE REQ - 153D - Driving time-out error
SERVICE REQ - 153E - Velocity deviation error
SERVICE REQ - 153F - Lock error
SERVICE REQ - 1540 - Cutter HP detection error
SERVICE REQ - 1541 - Cutter return error
SERVICE REQ - 1549 - Motor disconnection error
SERVICE REQ - 154A - Overload error
SERVICE REQ - 154B - Over speed error
SERVICE REQ - 154C - Reversing error
SERVICE REQ - 154D - Driving time-out error
SERVICE REQ - 154E - Velocity deviation error
SERVICE REQ - 154F - Lock error
SERVICE REQ - 1551 - Paper thickness determining error
SERVICE REQ - 1561 - Paper thickness at power-on error
SERVICE REQ - 1A23 - Incorrect RTC data error
SERVICE REQ - 1A26 - RTC Access T/O error
SERVICE REQ - 1A37 - Thermistor error
SERVICE REQ - 1A38 - Transistor environmental temperature error
SERVICE REQ - 1A40 - IC22 error
SERVICE REQ - 1A50 - I2C communication error (Between elements on ASIC and MAIN)
SERVICE REQ - 1A51 - I2C communication error (Between elements on SUB and MAIN)
SERVICE REQ - 1A52 I- 2C communication error (Between elements on SUB-B and MAIN)
SERVICE REQ - 1A53 - I2C communication error (Between elements on SUB-C and MAIN)
SERVICE REQ - 2003 - FLASH BOOT SUM CHECK error
SERVICE REQ - 200A - F/W load error
SERVICE REQ - 2010 - UART communication error
SERVICE REQ - 3000 - AC shut-off
SERVICE REQ - D131 - AID error
SERVICE REQ - Fxxx - CPU-related error
SERVICE REQ - Dxxx - Debug error
Spectroproofer and Auto Take-Up Error Codes
NOTE: SpectroProofer-related errors do not occur on Epson Stylus Pro 7700/7710/7700M/7710M/9700/9710 because it does not support the SpectroProofer.
Auto Take-up Reel-related errors do not occur on Epson Stylus Pro 7700/7710/7700M/7710M/7900/7910/WT7900/WT7910//7890/7908 because it does not support the Auto Take-up Reel.
Errors related to the SpectroProofer and Auto Take-up Reel do not occur on Epson Stylus Pro 7700M/7710M.
D3 - Driving auto take-up system
D6 - Driving paper pressing system
65 - Cooling Fan lock detection error
12 - Paper Pressing Plate Sensor no detection error
13 - Foreign material detection error in paper pressing
14 - Paper pressing origin position detection failure error
15 - CR HP Sensor no detection error
16 - Paper pressing system abnormal measurement value error
17 - Take-up system abnormal measurement value error
20 - Slack Sensor no detection error
01 - Mechanism is not installed -(Mount Sensor is OFF)
30 - Driving time-out error
31 - Overload error
32 - Over speed error
33 - Reversing error
34 - Velocity deviation error
35 - Lock error
40- Driving time-out error
41 - Overload error
42 - Over speed error
43 - Reversing error
44 - Velocity deviation error
45 - Lock error
20 - Driving time-out error
Epson 7600 9600 Error Codes
Maintenance Requests Errors
MAINTENANCE REQ - 0040 - Cleaning unit is nearing the end of life.
MAINTENANCE REQ - 0002 - Carriage motor is nearing the end of life.
MAINTENANCE REQ - 0008 - RTC backup battery is empty.
MAINTENANCE REQ - 0020 - The number of shots (per nozzle) reaches the limit .
MAINTENANCE REQ - 0088 - The RTC backup battery is not installed.
MAINTENANCE REQ - 0080 - Data is not specified.
MAINTENANCE REQ - 0100 - RTC backup battery is dropped instantaneously.
SERVICE REQ - 00000101 - CR motor life
SERVICE REQ - 00010000 - PF motor encoder check error
SERVICE REQ - 00010001 - PF motor out of step
SERVICE REQ - 00010002 - PF motor overcurrent
SERVICE REQ - 00010003 - PF motor in-position time-out
SERVICE REQ - 00010004 - CR motor encoder check error
SERVICE REQ - 00010005 - CR motor out of step
SERVICE REQ - 00010006 - CR motor overcurrent
SERVICE REQ - 00010007 - CR motor in-position time-out
SERVICE REQ - 00010008 - Servo interrupt watchdog time-out
SERVICE REQ - 00010009 - System interrupt watchdog time-out
SERVICE REQ - 0001000A - CR home position sensor error
SERVICE REQ - 0001000B - PF home position sensor error
SERVICE REQ - 0001000C - Head slide (PG) home position sensor error
SERVICE REQ - 0001000F - CR motor PWM output faulty
SERVICE REQ - 00010010 - PF motor PWM output faulty
SERVICE REQ - 0001001B - Head driver (TG) temperature error
SERVICE REQ - 0001001D - CR servo parameter error
SERVICE REQ - 0001001E - PF servo parameter error
SERVICE REQ - 00010020 - CSIC reed/right error
SERVICE REQ - 00010022 - Ink type error (setting on printer body side)
SERVICE REQ - 00010023 - RTC analysis error
SERVICE REQ - 00010025 - CSIC ROM communication error
SERVICE REQ - 00010026 - RTC communication error
SERVICE REQ - 00010028 - Head error
SERVICE REQ - 00010029 - Unidentified NMI
SERVICE REQ - 0001002A - CR ASIC ECU error
SERVICE REQ - 0001002B - PF ASIC ECU error
SERVICE REQ - 00020000 - NVRAM error
SERVICE REQ - 00020002 - SDRAM error
SERVICE REQ - 00020003 - BOOT program SUM error
SERVICE REQ - 00020004 - NVRAM error (3K)
SERVICE REQ - 00020005 - NVRAM error (32K)
SERVICE REQ - 00020009 - Flash memory SUM error
SERVICE REQ - 0002000A - Program load error
SERVICE REQ - 0002000B - Internal memory shortage error
SERVICE REQ - 0002000C - Review error
SERVICE REQ - 100000E0 - CPU address error (load misalignment)
SERVICE REQ - 10000100 - CPU address error (storage misalignment)
SERVICE REQ - 10000180 - CPU reserve command code exception error
SERVICE REQ - 100001A0 - CPU slot illegal command exception error
SERVICE REQ - 100005C0 - CPU DMA address error
SERVICE REQ - 10000xxx - CPU error
Epson 7xx0 9xx0 Error Codes
MAINTENANCE REQ - 0002 - The number of carriage movement cycles reached the specified value.
MAINTENANCE REQ - 0008 - The RTC backup battery run down or is not installed.
MAINTENANCE REQ - 0040 - The pump counter reached the specified upper limit.
MAINTENANCE REQ - 0080 - The date and time has not been set.
MAINTENANCE REQ - 0100 - A momentary drop in voltage of the RTC backup battery
MAINTENANCE REQ - 0400 - The Pressure Pump counter reached the specified upper limit.
SERVICE REQ - 00000101 - The CR Motor reached its end of life.
SERVICE REQ - 00010000 - PF Encoder check error
SERVICE REQ - 00010001 - The PF Motor is out of step.
SERVICE REQ - 00010002 - Overcurrent occurred on the PF Motor.
SERVICE REQ - 00010003 - The PF Motor out of position time-out error
SERVICE REQ - 00010004 - CR Encoder check error
SERVICE REQ - 00010005 - CR Motor is out of step.
SERVICE REQ - 00010007 - The CR Motor out of position time-out error
SERVICE REQ - 00010008 - Servo interrupt watchdog time-out error
SERVICE REQ - 00010009 - System interrupt watchdog time-out error
SERVICE REQ - 0001000A - Carriage home position detection error
SERVICE REQ - 0001000C - PG home position detection error
SERVICE REQ - 00010014 - Failure of pressurizing
SERVICE REQ - 00010020 - CSIC reading/writing error
SERVICE REQ - 00010023 - RTC analyzing error
SERVICE REQ - 00010027 - Pressure pump micro air-leak error
SERVICE REQ - 0001002D - The Cleaning Unit reached its end of life.
SERVICE REQ - 00010035 - Pump phase detection error
SERVICE REQ - 00010036 - Type-B board installation error
SERVICE REQ - 00010037 - Head thermistor error
SERVICE REQ - 00010038 - Transistor thermistor error
SERVICE REQ - 0001003E - Pressure Sensor failure
SERVICE REQ - 0001003F - The Pressure Motor reached its end of life.
SERVICE REQ - 00010040 - Printing position error
SERVICE REQ - 00020003 - Boot program sum error
SERVICE REQ - 0002000B - The internal memory is insufficient.
SERVICE REQ - 0Dxxxxxx - An error code for debugging
SERVICE REQ - 0Exxxxxx - A time-lag of the RTC timer
SERVICE REQ - 100000E0 - CPU address error (load)
SERVICE REQ - 10000100 - CPU address error (store)
SERVICE REQ - 10000180 - CPU reserved command code exception error
SERVICE REQ - 100001A0 - CPU slot undefined command exception error
SERVICE REQ - 100001C0 - The AC power is shut off.
Epson 4900 4910 Error Codes
MAINTENANCE REQ - 0800 - Cartridge holder diaphragm near end of life
MAINTENANCE REQ - 1000 - Ink Selector near end of life
SERVICE REQ - 1412 - Motor Life Error
SERVICE REQ - 1432 - IC Holder life error
SERVICE REQ - 1433 - IS Unit position sensor error
SERVICE REQ - 1520 - Roll feed motor lock retry error
SERVICE REQ - 1521 - Roll feed sensor detect error
SERVICE REQ - 1523 - Roll sensor error
SERVICE REQ - 1530 - HP detection error
SERVICE REQ - 1531 - Release Sensor error
SERVICE REQ - 154B - Cutter Motor over speed error
SERVICE REQ - 154C - Cutter Motor reversing error
SERVICE REQ - 155A - DCP Motor overload error
SERVICE REQ - 155B - DCP Motor over speed error
SERVICE REQ - 155C - DCP Motor reversing error
SERVICE REQ - 155D - DCP Motor driving time-out error
SERVICE REQ - 155E - DCP Motor velocity deviation error
SERVICE REQ - 155F - DCP Motor lock error
SERVICE REQ - 1562 - ASF Motor abnormal load detection error
SERVICE REQ - 156A - ASF Motor overload error
SERVICE REQ - 156B - ASF Motor over speed error
SERVICE REQ - 156C - ASF Motor reversing error
SERVICE REQ - 156D - ASF Motor driving time-out error
SERVICE REQ - 156E - ASF Motor velocity deviation error
SERVICE REQ - 156F - ASF Motor lock error
SERVICE REQ - 1571 - ASF Retard Roller Sensor operation error
SERVICE REQ - 1572 - ASF Pickup Roller operation error
SERVICE REQ - 1573 - ASF Assist Roller operation error
SERVICE REQ - 157A - ASF Sub Motor overload error
SERVICE REQ - 157B - ASF Sub Motor over speed error
SERVICE REQ - 157C - ASF Sub Motor reversing error
SERVICE REQ - 157D - ASF Sub Motor driving time-out error
SERVICE REQ - 157E - ASF Sub Motor velocity deviation error
SERVICE REQ - 157F - ASF Sub Motor lock error
SERVICE REQ - 1581 - Paper eject position error
SERVICE REQ - 1582 - ASF Edge Guide open/close error
SERVICE REQ - 158A - EG Motor overload error
SERVICE REQ - 158B - EG Motor over speed error
SERVICE REQ - 158C - EG Motor reversing error
SERVICE REQ - 158D - EG Motor driving time-out error
SERVICE REQ - 158E - EG Motor velocity deviation error
SERVICE REQ - 158F - EG Motor lock error
SERVICE REQ - 159A - ATC Motor overload error
SERVICE REQ - 159B - ATC Motor over speed error
SERVICE REQ - 159C - ATC Motor reversing error
SERVICE REQ - 159D - ATC Motor driving time-out error
SERVICE REQ - 159E - ATC Motor velocity deviation error
SERVICE REQ - 159F - ATC Motor lock error
SERVICE REQ - 1801 - AID voltage error
SERVICE REQ - 1ABx - Main Board communication error
SERVICE REQ - 1Fxx - ILS error (1)
SpectroProofer Errors
01 - SpectroProofer uninstallation error
02 - Paper Eject Support uninstallation error
65 - Drying Fan lock detection error
80 - ILS calibration error
D5 - CR related drive error
D6 - Paper pressing related operating error
Epson 4xx0 Error Codes
MAINTENANCE REQ - 0002 - The number of CR movement cycles has reached predetermined value
MAINTENANCE REQ - 0008 - RTC backup battery shut off
MAINTENANCE REQ - 0040 - Pump counter has reached predetermined amount.
MAINTENANCE REQ - 0080 - Date is not set
MAINTENANCE REQ - 0088 - RTC backup battery is not installed.
MAINTENANCE REQ - 0100 - RTC backup battery pressure is temporally low.
MAINTENANCE REQ - 0200 - The number of ASF paper feeding has reached predetermined value.
SERVICE REQ - 00000101 - CR Motor life
SERVICE REQ - 00010000 - PF Motor Encoder check error
SERVICE REQ - 00010001 - PF Motor out of step
SERVICE REQ - 00010002 - PF Motor over current
SERVICE REQ - 00010003 - PF Motor in-position time-out
SERVICE REQ - 00010004 - CR Motor Encoder check error
SERVICE REQ - 00010005 - CR Motor out of step
SERVICE REQ - 00010006 - CR Motor over current
SERVICE REQ - 00010007 - CR Motor in-position time-out
SERVICE REQ - 0001000A - CR axis detection error
SERVICE REQ - 0001000C - PG axis detection error
SERVICE REQ - 0001000F - CR Motor PWM output faulty
SERVICE REQ - 00010010 - PF Motor PWM output faulty
SERVICE REQ - 00010012 - CR overload (high sensitivity) error
SERVICE REQ - 00010013 - PR overload (high sensitivity) error
SERVICE REQ - 0001002D - Cleaning Unit work life error
SERVICE REQ - 0001002F - 360 DPI writing time out error
SERVICE REQ - 00010030 - Multi Sensor failure
SERVICE REQ - 00010031 - ASF phase detection error
SERVICE REQ - 00010032 - ASF drive switch error
SERVICE REQ - 00010033 - Eject phase detection error
SERVICE REQ - 00010034 - Eject movement error
SERVICE REQ - 00010039 - PG adjustment value incorrect overwrite error
SERVICE REQ - 0001003A - PG adjustment value outside range error
SERVICE REQ - 0001003B - Cutter installation error 1
SERVICE REQ - 0001003C - Cutter installation error 2
SERVICE REQ - 0001003D - Cutter installation error 3
SERVICE REQ - 100001C0 - AC disruption
SERVICE REQ - 0003xxxx - Debug error code
SERVICE REQ - 0Dxxxxxx - Debug error code
SERVICE REQ - 0Exxxxxx - RTC timer off error
Epson 4000 Error Codes
SERVICE REQ - 00001002A - CR ASIC ECU error
Epson 10000 10600 Error Codes
MAINTENANCE REQ - 0100 - Indicates small quantity of remaining waste ink material absorption.
MAINTENANCE REQ - 0101 - The CR motor reached the 3% remaining to the life.
MAINTENANCE REQ - 0102 - Auto nozzle check error
MAINTENANCE REQ - 0103 - Backup battery for RTC (real time clock) life expired.
MAINTENANCE REQ - 0104 - Dot missing detector error
SERVICE REQ - 00000100 - Waste ink pads are full
SERVICE REQ - 00000101 - CR motor life (Ink tubes also reached their life)
SERVICE REQ - 00000102 - Nozzle check error compulsory continuity
SERVICE REQ - 00000103 - RTC backup battery end
SERVICE REQ - 00000104 - Auto print head optimization system
SERVICE REQ - 00000105 - Head unit life end
SERVICE REQ - 00000106 - Cleaning unit life end
SERVICE REQ - 00010000 - PF motor/ encoder check error
SERVICE REQ - 00010001 - PF motor step-out
SERVICE REQ - 00010002 - PF motor/overcurrent
SERVICE REQ - 00010003 - PF motor/ in position time-out error
SERVICE REQ - 00010004 - CR motor/ encoder check error
SERVICE REQ - 00010005 - CR motor step-out
SERVICE REQ - 00010006 - CR motor/overcurrent
SERVICE REQ - 00010007 - CR motor/ in position time-out error
SERVICE REQ - 00010008 - Servo interruption watch dog time out error
SERVICE REQ - 00010009 - System interruption watch dog time out error
SERVICE REQ - 0001000A - CR origin sensor mulfanction
SERVICE REQ - 0001000B - PF origin sensor mulfanction
SERVICE REQ - 0001000C - HS origin sensor mulfanction
SERVICE REQ - 0001000D - Cover sensor mulfanction
SERVICE REQ - 0001000E - Cover sensor mulfanction
SERVICE REQ - 0001000F - CR motor over heat (PWM output malfunction)
SERVICE REQ - 00010010 - PF motor over heat (PWM output malfunction)
SERVICE REQ - 00010011 - Paper jam error
SERVICE REQ - 00010012 - Cap origin error
SERVICE REQ - 00010013 - Providing system origin error
SERVICE REQ - 00010014 - Pressurization error
SERVICE REQ - 00010015 - Liquid sensor overflow (K)
SERVICE REQ - 00010016 - Liquid sensor overflow©
SERVICE REQ - 00010017 - Liquid sensor overflow (M)
SERVICE REQ - 00010018 - Liquid sensor overflow (LC)
SERVICE REQ - 00010019 - Liquid sensor overflow (LM)
SERVICE REQ - 0001001A - Liquid sensor overflow (Y)
SERVICE REQ - 0001001C - FS origin (Suction fan shutter home position) error
SERVICE REQ - 00010020 - CSIC card read/write error
SERVICE REQ - 00010021 - Starter cartridge error
SERVICE REQ - 00010022 I- nk type NVRAM status error
SERVICE REQ - 00010023 - RTC operation malfunction
SERVICE REQ - 00010024 - Module communication time-out error
SERVICE REQ - 00010025 - CSIC EEROR access error
SERVICE REQ - 00010026 - RTC access error
SERVICE REQ - 00010027 - Pressure pump small leak error
SERVICE REQ - 00010028 - During cleaning, pressure pump small leak error
SERVICE REQ - 00020001 - NVRAM check sum error
SERVICE REQ - 00020003 - Flash memory sum error
SERVICE REQ - 00020004 - ASIC illegal version error
SERVICE REQ - 00020005 - Firmware ASIC mismatching error (Version:A)
SERVICE REQ - 00020006 - Firmware ASIC mismatching error (Version:B)
SERVICE REQ - 00020007 - Head/ASIC mismatch error
SERVICE REQ - 00020009 - Flash memory check sum error
SERVICE REQ - 0002000B - Memory insufficient error
SERVICE REQ - 00030000 - 00030013 - Debug error
SERVICE REQ - 00030015 - Ink supply defective (K)
SERVICE REQ - 00030016 - Ink supply defective ©
SERVICE REQ - 00030017 - Ink supply defective (M)
SERVICE REQ - 00030018 - Ink supply defective (LC)
SERVICE REQ - 00030019 - Ink supply defective (LM)
SERVICE REQ - 0003001A - Ink supply defective (Y)
SERVICE REQ - 0003001B - GAP adjustment range error
SERVICE REQ - 0003001C - Timeout in case of no print finishing with ASIC
SERVICE REQ - D0120013 - Module comminication error
SERVICE REQ - D012001E - Engine side ASIC command transmission over flow
SERVICE REQ - D012001F - Engine side ASIC command receiption over error
SERVICE REQ - D0xxxxxx - Program error
SERVICE REQ - 10000E0 - CPU address error
SERVICE REQ - 1000100 - CPU address error
SERVICE REQ - 10000180 - CPU reservation instruction code exception error
SERVICE REQ - 100001A0 - CPU Slot unfair command exception error
SERVICE REQ - 10000xxx - CPU illegal trap
SERVICE REQ - FFFFxxxx - OS kernel detection error
Сервисные коды
| Сообщение #2 Отправлено 20 октября 2012 - 18:43
Уважаю за потраченное Вами время. Это ж сколько нужно было гектар мануалов перелопатить... Да еще в ущерб выходным...
Только шо-то энтот момент совпал с окончанием сезона сервис-тренингов и раздачи дисков с локументацией...
| Сообщение #3 Отправлено 20 октября 2012 - 18:46
Человек по работе парится, заодно и поделился с коллегами. РЕСПЕКТ !
| Сообщение #4 Отправлено 20 октября 2012 - 19:00
Хотите великий секрет открою ? :-)
Некоторая информация, выдернутая из контекста, мало ценная сама по себе. Тот кто не знает (например) что такое SERVICE REQ - 1496 - Ink selector sensor error detection тому может быть и не надо это. А кто с этим инк селектором натрахался вволю до чертиков - найдет расшифровку кода за 5 секунд и в первую очередь...
Но все равно - респект, например я полгода выискивал в открытой/ДСП/совсекретной документации полный список кодов ошибок, содержащихся в ответе принтера/плоттера на запрос статуса, приходящий ему по USB. (всего их может быть 255) Очень нуно было...
| Сообщение #5 Отправлено 20 октября 2012 - 19:28
Ребята, все куда гораздо проще :-) Искал код ошибки к Epson 10600, наткнулся на этот "список" и передернул его сюда. Он мне помог, вот и решил, вдруг и тут найдет себе приминение.
| Сообщение #6 Отправлено 27 ноября 2012 - 08:35
Добрый день,
Уважаемые поклонники пьезоэлектрической технологии струйной печати, не скажу какой фирмы.
Работаю рядом с официальным сервисом Epson, не скажу в какой компании.
На ремонт принесли негарантийный pro 4900. На экране при включении 1F80 ILS error, ILS control error has occurred. The fuse of the Main Board has blown. Replace the Main Board. Были проверены все найденные предохранители на материнской плате и все они в рабочем состоянии. Далее поверили принтеру и заказали материнскую плату. Пришла, установили с подключением всех кабелей. При включении та же ошибка 1F80. Отключили два кабеля идущих к сетевой плате, принтер завелся и попросил Clear NVRam. Выполнил инициализацию и вышел на готовность. Странно, потому, что еще со старой материнской платой, сетевую платой я отключал и принтер сообщал об ошибке 1F80 стабильно.
Дальше интереснее, после включения питания и нормальной инициализации принтер вывел ошибку 0080 (ошибка даты и времени). После выключения прнтер опять стал стабильно выводить ошибку 1F80 и теперь ни со старой ни с новой материнскими платами ни с подключенной ни с отключенной сетевой платой инициализироваться не хочет, постоянно ошибка 1F80.
Подскажите что это может быть?
Спасибо.
Спасибо.
| Сообщение #7 Отправлено 26 декабря 2023 - 14:44
Добрый день, уважаемые форумчане! Имею хороший плоттер Epson(Maxart) px-9500S. Приобретал б/у в 2019 году. Служит верой и правдой , отпечатал уйму чертежей и прочих картинок. На днях печатал большой заказ афиш в полном цвете и в процессе печати вылезло следующее сообщение "maintenance request 2000". Вроде как предложение об обслуживании. Плоттер продолжает работать, но сообщение висит. Погуглил ничего найти не смог, может кто сталкивался с таким сообщением? Помогите!
Epson T50, Т59, L800, maxart px 9500S, HP Officejet Pro X451dw, HP Officejet Pro 8100
| Сообщение #8 Отправлено 26 декабря 2023 - 16:37
Может, просто сбросить эту ошибку? https://forum.resett...showtopic=31136
| Сообщение #9 Отправлено 26 декабря 2023 - 16:48
Pitlord, пробовал. К сожалению не помогло.
Инфо (3 457)
