Какизбавиться от сообщений типа Maintenance Message - требуется обслуживание:
HP IIISi Printers:
Press ONLINE until the light goes off
Hold down MENU until PCL CONFIG MENU appears
Press the MENU key until SERVICE MSG=ON* appears
Press the + or - key to change display to SERVICE MSG=OFF
Press ENTER/RESET MENU key to turn message off, the * should appear, then press ONLINE
HP 4Si Printers:
Press MENU until CONFIG MENU appears
Press the ITEM key until SERVICE MSG=ON* appears
Press the ENTER key to turn message off, the * should appear, then press ONLINE
HP 5Si:
Press MENU key 4 times for CONFIG MENU
Press ITEM to display SERVICE MESSAGE=OFF
Press ENTER
Press ONLINE
HP 4000/4050/4100/5000 Printers:
Turn the printer off
Hold down the left side of the ITEM and VALUE +/- keys, turn the printer on and wait until RESET MAINTENANCE COUNT is displayed and then release the keys
HP 4500/4550 Printers:
Hold down the CANCEL JOB and SELECT keys and turn the printer on, then wait until the display goes blank and the three LED's come on
Press the right side of the MENU key, then press the SELECT key
You will enter SERVICE MODE after the normal test completes
Press the ITEM key until the FUSER MAINTENANCE COUNT appears
Press VALUE +/- to change to zero
Press SELECT to save
Press GO; the printer should return to READY
HP 8000/8100/8150 Printers:
Press the MENU button until the display reads CONFIGURATION MENU
Press the ITEM button until the display reads SERVICE MESSAGE = ON/OFF
Select OFF*
Turn printer off
Hold the VALUE MINUS and ITEM MINUS buttons while turning the printer back on Hold buttons down until display reads RESET MAINT/COUNTand then release both buttons
HP 9000 Printers:
Press and hold the CHECK key
Power on the printer
Release the CHECK key after all three lights come on The display should read SELECT LANGUAGE
Press the up arrow until MAINTENANCE KIT is displayed, then press the CHECK key again and the maintenance kit count has been reset
HP Color LaserJet 4500/4550 Printers (TRANSFER KIT RESET):
Press the MENU button until the RESETS MENU is displayed
Press the ITEM button until TRANSFER KIT SELECT IF DONE is displayed
Press the SELECT button
HP Color LaserJet 4500/4550 Printers (FUSER KIT RESET):
Press the ITEM buton until FUSER KIT SELECT IF DONE is displayed
Press the GO button to return to READY
HP Color LaserJet 4600 Printer (IMAGE TRANSFER KIT (ETB) RESET):
After Maintenance is performed, the display should read NEW TRANSFER KIT =
Press the down arrow to highlight YES, then press the CHECK button to reset Or enter CONFIGURE DEVICE in menus, choose RESETS then RESET SUPPLIES, choose NEW TRANSFER KIT and select
HP Color LaserJet 4600 Printer (FUSER KIT RESET):
After Maintenance is performed, the display should read NEW FUSER KIT =
Press the down arrow to highlight YES, then press the CHECK button to reset Or enter CONFIGURE DEVICE in menus, choose RESETS then RESET SUPPLIES, choose NEW FUSER KIT and select
HP Color LaserJet 8500/8550 Printers (TRANSFER KIT RESET):
Press the ITEM button until RESET TRANSFER LIFE COUNT is displayed
Press the SELECT button to reset, then GO to return to READY
HP Color LaserJet 8500/8550 Printers (FUSER KIT RESET):
Press the ITEM buton until RESET FUSER LIFE COUNT is displayed
Если у кого есть что-то полезное в этом плане еще - пишите в форум или в приват - выложим!
Сброс сервисных сообщений для лазерников HP Как избавиться от сервисных сообщений?
| Сообщение #1 Отправлено 01 февраля 2006 - 10:28
Тема закрыта
Инфо (4 952)
